1. steve248's Avatar
    My LG G5 turns off at 15 percent battery and it is brand new. I already done a factory reset and has done nothing.
    08-19-2018 06:58 PM
  2. Itsa_Me_Mario's Avatar
    Put it on the charger before 20%, should solve that.
    08-19-2018 07:01 PM
  3. Rukbat's Avatar
    You should never allow the battery to drop below 40%. If you've been dropping it below 15% for a long time (the phone came out over 2 years ago), it's surprising that it lasted this long. (You also shouldn't charge it to more than 80% if you want it to last a long time.) It's probably time to replace the battery - and start treating it properly. (Lithium batteries were chosen for cellphones because lithium is the lightest metal [except for hydrogen around absolute zero], not for their ability to be deeply discharged. For that you'd need a gel cell, and that would weigh more than the phone - and be as large.)
    08-20-2018 04:30 PM
  4. Mike Dee's Avatar
    Even though it's new the battery may have degraded.
    08-20-2018 07:32 PM
  1. For the AT&T Cameox 5044R... Want Wifi setup Only! No Activation...
    By Phil Newsome in forum General Help and How To
    Last Post: 09-01-2018, 03:44 PM
  2. LG V10 can't play videos above FHD (1080p)
    By SVKFighter17 in forum LG V10
    Last Post: 08-21-2018, 10:46 PM
  3. Can not find the app drawer on my new LG phone
    By MissAlanaNicoleS in forum Ask a Question
    Last Post: 08-19-2018, 10:38 PM
  4. Galaxy S5 Battery Question
    Last Post: 08-19-2018, 02:36 PM
  5. LG G7 vs Huawei mate 10 pro
    Last Post: 08-19-2018, 12:10 PM
