    I wanted to replace my battery and as I took it out only the base came off. The actual battery is still stuck inside the phone. What do I do?
    09-20-2018 07:44 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Was the battery failing (i.e., draining quickly, not holding charge, getting warm easily)? If so, it might be swollen, causing it to get stuck. You should probably bring it to a repair shop to help remove it, since trying to grab it with some kind of tool to pull it out could cause damage and potential fire hazard.
    09-21-2018 02:35 PM
  1. The tale of three Moto Mods and my Z3 battery
    By sullywagon in forum Moto Z
    Last Post: 11-25-2018, 09:10 PM
  2. Can someone do a comparison with the original pixel in?
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 09-22-2018, 01:37 AM
  3. Dedicated Samsung apps are awesome - kinda like 'phone plug-ins'
    By KillerQ in forum Samsung Galaxy Note 9
    Last Post: 09-21-2018, 12:55 PM
  4. Music in playlists are being overwritten
    By TelvisTed in forum Android Apps
    Last Post: 09-20-2018, 07:07 PM
  5. Can someone do a comparison with the original pixel in?
    Last Post: 09-20-2018, 05:43 PM
