1. Kyleluvsandroid's Avatar
    My lg g5 ls992 is not recognized by a computer when i plug it in. If I do something to make windows refresh the driver it shows usb device not recognized for a short time. Windows makes the connected sound and within 30 seconds makes the disconnected sound while it is still plugged in. My wife has the same phone and her works fine. I have tried everything, reinstall drivers, usb debugging, usb mode, factory reset. I even tried swapping the bottom module. Nothing is working.
    02-06-2019 07:49 PM
  2. B. Diddy's Avatar
    You've also tried different cables, I assume?
    02-06-2019 08:03 PM
  3. Kyleluvsandroid's Avatar
    Yes, tried 2 cables and wifes phone, same model and age, works with it
    02-06-2019 09:50 PM
  4. B. Diddy's Avatar
    In that case, I'd wonder if there's some problem with the connection between the bottom module and the main body. Not sure what else you can do besides bringing it to a repair shop -- I assume it's no longer under warranty.
    Rukbat likes this.
    02-06-2019 10:01 PM
  1. Replies: 6
    Last Post: 02-26-2019, 11:15 AM
  2. Bixby works better for me with pie update
    By amyf27 in forum Samsung Galaxy Note 9
    Last Post: 02-08-2019, 04:45 AM
  3. Phone has not updated in months
    By electronicwiz1 in forum Samsung Galaxy S9 & S9+
    Last Post: 02-07-2019, 05:47 AM
  4. WiFi file transfer app stopped working
    Last Post: 02-06-2019, 03:58 PM
