    hello,
    i have lg g5 and its about 2 years old. the problem started before 4 months ago. i have even 100% of my battery but when i turn it off or when i take out the battery. i am unable to open even i press power botton. i have to put it in charger for 5 to 6 hours.and then it opens. but i have to put in for this much long before i never had this problems. it would be great if you gave me some suggestion
    02-08-2019 06:38 AM
  2. Rukbat's Avatar
    It sounds like a bad battery. In the future, when you turn the phone off, remove the battery. Don't put it back in until you're ready to turn the phone on again. If it still happens, the battery is bad. That's a bit unusual for a battery that's less than 3 years old, but it can happen, especially if you normally let it run down to almost 0 before charging it.
    (If it works by keeping the battery out, there's something shorted inside the phone which would probably require a new motherboard, so you'd have to see whether it pays to do that or to just replace the phone.)
    02-08-2019 01:17 PM
  3. alish khatri's Avatar
    the thing is i just bought new battery and it happens the same. probably its motherboard problem
    thank you for some suggestion.....may be i will try to change board or buy new one .....
    02-08-2019 06:24 PM
  1. Note 5 wont charge usb or wireless
    By smoke skull in forum Samsung Galaxy Note 5
    Last Post: 02-09-2019, 05:41 PM
  2. keep getting stock android icon rather than the actual app icon
    Last Post: 02-08-2019, 04:00 PM
  3. Samsung Galaxy S9 Plus keeping switching between LTE to LTE+ after screen replacement
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 02-08-2019, 01:48 PM
  4. Why is my music app not showing at all on samsung phone
    Last Post: 02-08-2019, 10:07 AM
  5. This showed up in my contacts: Free MetroPCS SMS for VVN
    Last Post: 02-08-2019, 06:00 AM
