ksmithservices
Active member
Same here. I fixed it and get 12+ hours with moderate use. Hibernation Manager app. Everytime you put your phone to sleep (lock it) it hibernates apps you select (I select everything except ones I want constant updates from like Facebook etc) and it slows my CPU to 300MHZ. Why does my CPU need to be at max in my pocket anyways? You can set it to turn off Bluetooth wifi and Sync also... No thanks. Finally... Use AutoSync for keeping your phone from syncing 24hrs. Email etc. I set mine to 15min meaning every 15min of sync being suspended it'll Sync for 3min and then turn off for 15min again. These apps are Flexible and VERY light. None of these crap apps like Greenify... They're complicated and have too many options. The apps I stated do only few things... What you want them too. Been a Couple weeks with Always-On Display on brighter setting always on and I unplug at 6am and have 30% roughly at 10pm. Usage varies but this IS the fix. Even if you don't mess with AutoSync because your a die-hard social app person.. The Hibernation Manager works wonders.
