    I try to bring the volume down but a few seconds later, it goes back to blasting at maximum volume all on its own. Can anyone help?
    06-15-2018 12:30 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The Volume Up button might be faulty or stuck. Make sure there isn't any sticky residue around the button.
    06-17-2018 01:08 AM
  3. jchapman01's Avatar
    Try cleaning the volume buttons with some rubbing alcohol and a tooth brush. Not too much, though. Then click the buttons a few times. If there's some gunk stuck in there, this might clean it out.
    B. Diddy likes this.
    06-19-2018 03:06 PM
  1. Replies: 5
    Last Post: 07-11-2018, 08:43 PM
  2. Hello new to the site!
    By Rogerkane in forum New to the Forums? Introduce Yourself Here!
    Last Post: 07-06-2018, 12:33 PM
  3. Replies: 5
    Last Post: 06-18-2018, 03:11 AM
  4. LG V30 SIlver
    By westiewanderer in forum Marketplace Archive
    Last Post: 06-15-2018, 01:26 PM
  5. Can you tell if someone has blocked your texts on their Android phone?
    Last Post: 06-15-2018, 01:18 AM
