1. patcal's Avatar
    Greetings,
    T-Mobile G6 here. Just updated to Oreo yesterday. Since then using my Samsung Fast charge pad, my phone only gets to 97% then stops & then will restart charging. Never had a problem getting to 100% before. Any ideas?
    Pat
    07-01-2018 05:00 PM
  2. patruns's Avatar
    Mine works fine. Try clearing the system cache.
    07-02-2018 08:57 AM
  3. patcal's Avatar
    Tried clearing cache. Also tried different cables, outlets, wall adapters & a different charging pad. Pretty sure it's the phone or should I say the software.
    Pat
    07-04-2018 07:40 AM
  4. Rukbat's Avatar
    Adaptive Fast Charge isn't exactly the same as Qualcom Quick Charge 3.0 - there are differences, and they may account for what you're seeing. (It's going to b at least another 2 years before everyone switches to Power Delivery [if everyone does] - so while any charger can charge any phone, they won't all work the same for a while.)
    07-04-2018 01:47 PM
  5. patcal's Avatar
    This has nothing to do with what I asked.
    07-04-2018 05:41 PM
  6. patcal's Avatar
    Well after putting it off, I finally did a factory reset. Did not fix my charging issue.
    07-08-2018 07:47 PM
  7. cohoman's Avatar
    I believe I had the same issue with my Samsung charging pad, so I switched to a different brand pad and it's been working fine charging to 100%.
    07-09-2018 04:50 AM
  1. Replies: 5
    Last Post: 07-06-2018, 10:55 AM
  2. My phone not charging properly
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 07-02-2018, 07:42 PM
  3. Strange 1% battery issue
    By Mark582 in forum Samsung Galaxy S8 & S8+
    Last Post: 07-02-2018, 03:15 PM
  4. iPhone issues
    Last Post: 07-01-2018, 01:08 PM
  5. My phone not charging properly
    Last Post: 07-01-2018, 12:52 PM
