1. Goosinurwife's Avatar
    it seems theres NO way to disable the tmobile sound at startup in oreo i cant find that anywhere help me i need to disable it asap its drivin me crazy
    07-01-2018 08:30 PM
  2. patcal's Avatar
    Unless your rooted you can't.
    07-01-2018 08:31 PM
  3. jchapman01's Avatar
    Could you disable in Nougat?
    07-02-2018 10:27 AM
  4. Goosinurwife's Avatar
    ya in nouget all you had to do was slide touch feedback and system to zero also it seems the tmobile app resets an trys to take over the phone im screwed i need to get back on the old android cuz this oreo sucks
    07-02-2018 03:14 PM
  5. hawklet00's Avatar
    just turn your phone to vibrate. why are you resetting your phone multiple times?
    07-02-2018 08:35 PM
  6. Goosinurwife's Avatar
    the vibrate function broke a month after i bought it
    07-02-2018 08:36 PM
  1. Oreo wireless charging issue
    By patcal in forum LG G6
    Last Post: 07-09-2018, 04:50 AM
  2. Replies: 1
    Last Post: 07-02-2018, 04:50 PM
  3. No LG Keyboard app
    By Velocirandy in forum LG K7
    Last Post: 07-02-2018, 12:20 PM
  4. lg g7 t mobile question
    By bracque in forum LG G7 ThinQ
    Last Post: 07-02-2018, 04:05 AM
  5. Why is the volume displayed on my home screen
    Last Post: 07-01-2018, 05:29 PM
