    Just got lg g6 about a month ago so card worked just fine then just stopped working for no reason
    03-14-2019 10:48 AM
  2. patruns's Avatar
    Did you try another card?
    03-15-2019 09:21 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! The SD card could be corrupt, defective, or counterfeit. Install SD Insight to see if the card is genuine or counterfeit. Counterfeit cards are programmed to report more storage than they actually have, and if you try saving more than the card can actually hold, then files can start getting corrupt. (Be aware that SD Insight might not work on all Nougat or above devices.)
    If it's a valid card, then go to Settings>Storage, Unmount the card, remove it, and insert it into your computer. Can the computer read these files? Backup as much as you can right now, then run chkdsk to look for bad sectors: http://forums.androidcentral.com/amb...d-sd-card.html.
    03-15-2019 10:16 PM
  1. My Samsung G7, answer and decline appears but does nothing when swiped
    Last Post: 03-14-2019, 02:23 PM
  2. Data Not working on My Phone.
    By Kirito_theBlackSwordsman in forum General Carrier Discussion
    Last Post: 03-14-2019, 12:58 PM
  3. Can i use the internet and call and talk to people at the same time
    Last Post: 03-14-2019, 10:50 AM
  4. My Samsung G7, answer and decline appears but does nothing when swiped
    Last Post: 03-14-2019, 09:51 AM
