    Please tell me there is a fix for this.
    Like another post my G6 is taking over 6 hours to charge. Even at 90% it takes 50 minutes to fully charge.
    The battery has been replaced with a factory LG BL-T32 ORIGINAL LG G6 H870 Battery 3300mAh 3.8 V.
    The USB-C charging port has been replaced.
    I use the plug charger that came with the phone.
    New USB-A to USB-C cables have been bought and tried.
    I have tried different Developer options and also disabled, deleted or forced stop apps that are not necessary.
    After this the phone has been factory reset and updated- Android 8.0.
    All hardware works fine, I can only imagine this is a software issue.
    Does anyone know anything on how to fix this?
    07-20-2019 01:21 PM
  2. evanborkow's Avatar
    Have you tried another charger?
    07-20-2019 02:14 PM
  1. Why does my phone drains so quickly and unexpectedly?
    Last Post: 07-20-2019, 03:49 PM
  2. My husband did a factory reset on my phone (S7 edge)
    Last Post: 07-20-2019, 03:39 PM
  3. Bluetooth settings keep shutting down when I go to open it
    Last Post: 07-20-2019, 01:44 PM
  4. Why is my screen red and it has bars going straight down
    Last Post: 07-20-2019, 12:41 PM
  5. why is my front camera not working?
    Last Post: 07-20-2019, 12:00 PM
