1. hrxv1's Avatar
    I have a new G6. On both Android 7 and Android 8, the flashlight is poorer than the flashlight that comes with the video camera.
    I have tried the G6 flashlight and also 4 flashlight apps. All of these produce a lower brightness compared to taking a video with the flash on. I tested it by using another camera and taking comparison pictures. There was an obvious quality difference, with the video "flashlight" picture being much brighter. Is this a problem with my particular phone? Is there a setting where I can increase the flashlight brightness?
    11-02-2019 04:27 AM
  2. patruns's Avatar
    I would think that this is by design. A brighter light is desired while filming to pick up every little detail in a dark setting. A flashlight just requires that you can see in the dark.
    11-02-2019 10:37 AM
  1. LG Q7+ data is no longer working after update
    Last Post: 11-04-2019, 06:06 PM
  2. Pictures taken from front camera of pixel 3a are getting inverted.
    Last Post: 11-02-2019, 08:01 PM
  3. BEST smartphone camera for motion/action shots
    By MoreDef in forum Buyers Guides
    Last Post: 11-02-2019, 05:57 PM
  4. Flashlight turned blue
    By rockyd57 in forum Ask a Question
    Last Post: 11-01-2019, 01:36 AM
