Battery life
spydersilk
133
18
I hate battery life threads, but I got my G7 Thurs afternoon and battery has been pretty disappointing.
Unfortunately under battery, the LG home launcher is the biggest culprit, at times showing as 30%. Even if I'm using a different launcher it still shows up number 1 on the list.
I'm guessing there is a way to use ADB to debloat or disable some of the apps.
Aside from that, really happy with the phone.
Tsepz_GP
1,385
You are not the only one, Tom's Guide seems to be seeing the same thing with their G7
https://www.tomsguide.com/us/lg-g7-thinq,review-5390.html
spydersilk
133
18
I had the v30 prior and was pretty pleased with battery life on that.
Hopefully things just settle in and battery gets better.
sushiguy732
1,351
46
Can I ask why did you decide to go from the V30 to the G7? From what I understand there is no real benefit which is why I was struggling with the decision myself.
spydersilk
133
18
I got the v30 back in October. My wife at the time had the Moto z2. After a few months, she wanted the v30 so we swapped. I'm not a big Samsung fan and despite the bum deal I think LG gets, I like the phones they make.
sjgoten6
99
how did the note 8 get better battery life than s9 plus? s9 plus has bigger battery and better software optimization with the SD845 (unless this was the other chipset)
bhatech
Trusted Member
Nov 21, 2012
7,850
488
83
Yesterday wasn't a full day, and spent time setting up the phone etc. Now that everything is set up, charged it up full overnight, I'll see how it does in terms of battery life today. I have plenty of other phones lying around so will be comparing to them. If it gets thru the day then no issues.
bhatech
Trusted Member
Nov 21, 2012
7,850
488
83
Yeah that's surprising and not my experience having used both of them. Most of these tests are not normal usage tests I believe, it's running videos continuously, doing certain things in a loop etc. Doesn't take into account how some phones handle standby, various network conditions, memory management etc.
While these tests are useful and give some reference point, it's not the whole story.
neil74
1,287
11
38
Have only been using mine for 24 hours so still settling in but I'd say that battery is a mixed bag so far. Standby is decent and better than the S9+ but it does seem to drop a little more under actual use. Better though than the smaller S9 on both counts
Overall I think battery looks fine albeit certainly not as great as some bigger phones.
bhatech
Trusted Member
Nov 21, 2012
7,850
488
83
Couldn't test all the way till zero yesterday but at around 4.30 PM yesterday still 37% still left with close to 5hrs SOT.
bhatech
Trusted Member
Nov 21, 2012
7,850
488
83
Interesting. I notice that your battery usage starts don't show Google Play Services. On my G7, Google Play Services is taking up a big Chuck on my battery.
Hmm yeah not sure, I tried to check in my other phones as well and I didn't see Google play services show up on any of them. Also, I'm not doing anything different. My google account sync is all set to default automatic, location services set to high accuracy. Basically everything left at the setting how it came out of the box just like all my other phones.
Also, for what it's worth I'm on play services beta from long time. Not sure if that makes a difference.
Racing24
136
Hmm yeah not sure, I tried to check in my other phones as well and I didn't see Google play services show up on any of them. Also, I'm not doing anything different. My google account sync is all set to default automatic, location services set to high accuracy. Basically everything left at it came out of the box just like all my other phones.
//uploads.tapatalk-cdn.com/20180603/afdc4b1058d49dc7d8da70777a934f8f.jpg
Interesting. How does one get on the Beta? I might have to give it a shot because compared to other Android phones I own, the Play Services drain on the G7 is unusually high and, frankly, disappointing.
bhatech
Trusted Member
Nov 21, 2012
7,850
488
83
Search for Google play services from settings. Once you select Google play services, scroll all the way down and click on app details, that should take you to the Google play store. In there scroll all the way down and check if you have option to enroll into beta.
Racing24
136
//uploads.tapatalk-cdn.com/20180603/e8e534e7edf661b6ecc515259a900f9c.jpg//uploads.tapatalk-cdn.com/20180603/991f47759abdb5c4a042e726edd6458e.jpg//uploads.tapatalk-cdn.com/20180603/2326f5aec9ffc5391104d2ead63d93c9.jpg
Thank you. Just signed up and waiting for the Beta setup to finalize.
D13H4RD2L1V3
Retired Moderator
Sep 4, 2013
4,407
I wouldn't be surprised if battery life turns out to be quite average.
A smaller-than-usual battery coupled with a bright display and a high-end processor isn't going to do wonders for battery.
It will probably get you through a day, but don't expect more.
