I setup my G7 yesterday. Ran into a couple issues with Textra and trying to find out how to clear the system cache.
I did a search to try and find out how to clear the system cache after I had everything setup, but I could not find anything. If you hold down the power button on the home screen, the only option is to restart is safe mode. I can't find anything to wipe the system cache. On the G4 it was one of many options on a screen.
I transferred my messages using SMS backup and restore via Google drive.
All of the messages show in the stock LG messages app. When I use Textra, all I get is message headers and there is nothing inside them. I cleared the data and cache in Textra, uninstalled it, and then installed it again with the same results. As a test I installed Chomp and all the messages populated normally. Any thoughts on how to fix the Textra issue. I emailed the developers, but haven't heard anything yet.
If I could figure out how to clear the system cache, I thinking maybe that would fix the Textra issue. I used Textra on my G4 with no problems.
