1. johnts's Avatar
    I setup my G7 yesterday. Ran into a couple issues with Textra and trying to find out how to clear the system cache.
    I did a search to try and find out how to clear the system cache after I had everything setup, but I could not find anything. If you hold down the power button on the home screen, the only option is to restart is safe mode. I can't find anything to wipe the system cache. On the G4 it was one of many options on a screen.
    I transferred my messages using SMS backup and restore via Google drive.
    All of the messages show in the stock LG messages app. When I use Textra, all I get is message headers and there is nothing inside them. I cleared the data and cache in Textra, uninstalled it, and then installed it again with the same results. As a test I installed Chomp and all the messages populated normally. Any thoughts on how to fix the Textra issue. I emailed the developers, but haven't heard anything yet.
    If I could figure out how to clear the system cache, I thinking maybe that would fix the Textra issue. I used Textra on my G4 with no problems.
    06-11-2018 02:43 PM
  2. Javier P's Avatar
    This is the closest it gets to a cache partition wipe on recent LG devices.
    Wiping System Cache/ Textra Problem-img_20180611_160510.jpg
    https://support.t-mobile.com/docs/DOC-37566
    06-11-2018 03:05 PM
  3. Rukbat's Avatar
    The system cache is for the system - for Android itself. If you want to clear the Textra cache, that's in Settings/Apps/Other apps/Textra, but I doubt it's a cache problem. But good luck.
    06-11-2018 03:07 PM
  4. sushiguy732's Avatar
    I too would like to know how to get into recovery mode.
    06-11-2018 03:51 PM
  5. johnts's Avatar
    I heard back from some of the guys at Textra. Apparently any LG phone running 8.0 is having a problem with Textra. They are working on a fix.
    06-12-2018 02:15 PM
  6. johnts's Avatar
    I had found this the day I setup my phone. I was hoping there was more than this option.
    06-12-2018 02:15 PM
  7. Javier P's Avatar
    I don't think there's such an option. IIRC LG removed the cache partition wipe from recovery some time ago, not sure why.
    06-12-2018 02:20 PM
  8. sushiguy732's Avatar
    Do you know how to get into recovery?
    06-12-2018 03:15 PM
  9. Javier P's Avatar
    I guess it's the same button combination than with the G6, but I'm not sure. Search for the right steps for your specific carrier, sometimes they change them.
    06-12-2018 03:27 PM
  10. sushiguy732's Avatar
    I've done searches to no avail.
    06-12-2018 04:13 PM
  1. Note 8 having problems Switching from Wifi to Cellular
    By Carrie Greicar in forum Samsung Galaxy Note 8
    Last Post: 06-13-2018, 11:24 AM
  2. S4 Active water damage (display problem)
    By Edember Ruazol in forum Ask a Question
    Last Post: 06-11-2018, 03:51 PM
  3. Problem with AZ Screen Recorder touches feature
    Last Post: 06-11-2018, 01:55 PM
  4. Problem installing APKs on Android phone
    Last Post: 06-11-2018, 12:14 PM
  5. Plz solve my problems fingerprint clean and dry
    Last Post: 06-11-2018, 08:27 AM
