1. venom0706's Avatar
    I've noticed that my G7's battery goes down 1% every 8-9 mins on Wi-Fi when browsing the Internet.
    However, when on 4G and 4G+, it dries 1% every 3-4 mins (when browsing the same webpages as on Wi-Fi).
    Is this normal? Phone is 2 weeks old, every app is updated. Sync and Location is switched off. Brightness is set at 30%. Battery saver is switched off.
    Thank you and appreciated.
    06-19-2018 09:32 AM
  2. TwitchyPuppy's Avatar
    If the LTE signal is weak, yes, it’s normal.
    Laura Knotek likes this.
    06-19-2018 09:52 AM
  3. B0WIE's Avatar
    4g is a notorious battery hog. Always been that way. It gets far worse if the phone is struggling to maintain a 4 signal.
    06-19-2018 10:17 AM
  4. flyingkytez's Avatar
    Maybe it's utilizing the new superfast LTE.. you can always change the speed to 4G or 3G on the mobile settings. Ask your carrier to do a signal reset, sometimes that works.
    06-19-2018 02:13 PM
  5. venom0706's Avatar
    Thanks.
    It's already on the 4G setting - the highest that says 2G/3G/4G Auto. The lesser below it is 2G/3G Auto.
    06-19-2018 07:10 PM
  6. Emily Baker's Avatar
    It's normal.Reason as below:
    The 4G signal uses the cellular data to access the Internet and requires high power to transmit data and find the network repeatedly. Therefore, the power consumption is high.
    The wifi is stable and there is no need to search for base stations frequently. The power is low, so the power consumption is low.
    B0WIE likes this.
    06-19-2018 11:22 PM
  1. How do I place my Game Apps back on the home screen?
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 06-19-2018, 04:22 PM
  2. I received Oreo for my Z Force on Verizon...
    By jimgravy in forum Moto Z
    Last Post: 06-19-2018, 02:45 PM
  3. My phone won't let me call out on my messenger
    Last Post: 06-19-2018, 06:36 AM
  4. I have a ANS UL40 that apparently uses a non removable battery
    By Albert Jones2 in forum Ask a Question
    Last Post: 06-19-2018, 06:12 AM
  5. Themes wont work after new update on s7 edge
    By Nucnud-90 in forum Android 8.0 Oreo
    Last Post: 06-19-2018, 02:56 AM
