1. johnnyshinta's Avatar
    I'm noticing that the top app battery consumer is my home app. I did see a thread about this on xda. Anyone here seeing this?
    CrCo likes this.
    07-11-2018 07:45 PM
  2. Bl00dRunzC0ld's Avatar
    Nope, not here. My home usage is low. I get really good battery life.
    Lg G7 "home" app battery drain-screenshot_2018-07-11-18-20-20.jpgLg G7 "home" app battery drain-screenshot_2018-07-11-18-20-32.jpg
    shaimere likes this.
    07-11-2018 08:24 PM
  3. johnnyshinta's Avatar
    Wow that's amazing battery life
    07-11-2018 08:34 PM
  4. Bl00dRunzC0ld's Avatar
    It's not too shabby. I'm always on LTE, keep my brightness at around 40% unless outside then it's on auto. Aod turned on from 5am to 10pm. Never use battery saver.
    07-11-2018 08:59 PM
  5. phillymade's Avatar
    I noticed at first the Home usage was very high, but about a week or two later it's not even on the map. Seems to have gotten itself under control
    07-12-2018 05:57 AM
  6. johnnyshinta's Avatar
    Thanks. I'll give it some time
    07-12-2018 06:10 AM
  7. johnnyshinta's Avatar
    Did either of you have the lg weather widget on your home screen
    07-12-2018 02:49 PM
  8. Bl00dRunzC0ld's Avatar
    I have the weather forecast widget on my screen. There only other widget I have on screen is calendar.
    07-12-2018 03:04 PM
  9. johnnyshinta's Avatar
    Cool thanks
    07-12-2018 04:22 PM
  10. phillymade's Avatar
    I still do.
    07-13-2018 09:20 AM
  11. Skevos Papageorgiou's Avatar
    during the first two or three weeks I was getting close to 6-6.5 hours battery with home app battery draining around 12%. Now I can barely go past 4.5-5 hours and home app gets around 20-30% minimum. AOD is off, weather and calendar widgets are on, brightness below 50, I don't play any games, most of the apps are just sitting there, didn't download any more apps since then except spotify and most of the use is on social media and youtube. Haven't really changed my habits from day one and that's why I am curious to find out what's draining the battery. All I can think of doing wrong is letting the battery go below 5% a couple of times when I had just bought it, which again does not justify 2 hours less battery life now.[ATTACH=CONFIG]287091[/ATTACHLg G7 "home" app battery drain-screenshot_2018-06-19-03-06-24.jpg
    Attached Thumbnails Lg G7 "home" app battery drain-screenshot_2018-06-19-03-05-55.jpg
    07-24-2018 10:59 AM
  12. CrCo's Avatar
    I'm having the same problem. I just got an LG G7 ThinQ and the home screen drained like 40% of my battery yesterday. I disabled the motion wallpaper to see if that helps. I also run the default weather app and changed the home screen to act more like traditional android with and app drawer. Funny thing is, my fiance got the same phone and is not having this problem.
    I'll keep an eye here for any fixes.
    07-24-2018 11:49 AM
  13. CrCo's Avatar
    As a followup from my last reply. Here's the home app's battery drainage since this morning...
    Attached Thumbnails Lg G7 "home" app battery drain-screenshot_2018-07-24-17-45-10.jpg
    07-24-2018 05:49 PM
  14. X1tymez's Avatar
    Yeah I'm having problem too. Wonder why?
    07-24-2018 10:21 PM
  15. DJ Steve Havoc's Avatar
    Why not use Battery Saver?
    09-04-2018 11:18 PM
  16. Bl00dRunzC0ld's Avatar
    I was saying that I never use battery saver, not that anyone else shouldn't.
    09-05-2018 05:08 PM
  17. cooper_m22's Avatar
    I have the same problem is anyone figured out a fix for this
    09-06-2018 04:21 PM
  1. Replies: 2
    Last Post: 07-12-2018, 05:32 PM
  2. Lower res more battery?
    By johnnyshinta in forum LG G7 ThinQ
    Last Post: 07-12-2018, 04:23 PM
  3. Monitoring real time traffic data per app
    Last Post: 07-12-2018, 05:47 AM
  4. Comment on the pop up app that comes from touching thr corner of the screen
    Last Post: 07-11-2018, 06:07 PM
  5. How do I reset my homescreen to how it was with the apps that were there
    Last Post: 07-11-2018, 04:26 PM
