1. flever's Avatar
    If notification setting and LED blink setting etc. are all enabled, do your G7 LED blink when receiving app notifications? Mine only blinks for a few apps but not others. The weird thing is that it doesn't even blink for the built-in email app when email is received.
    09-11-2018 12:54 PM
  2. Morty2264's Avatar
    Welcome to Android Central! My fiancé's G7 does get a notification light for app notifications. Which other apps do not receive notification LED on your end?
    09-11-2018 09:17 PM
  3. flever's Avatar
    Thanks.
    It doesn't blink for the built-in email app, McDonald's, Kijiji etc. There may be more I'll find out.
    09-12-2018 09:19 AM
  4. flever's Avatar
    Hi folks, do your G7 blink on the built-in Email app, and other apps? It would be helpful to determine if there is any software/hardware issue. LG support says send in the phone for inspection but I'm not sure if that will be helpful.
    09-17-2018 10:20 AM
  5. johnts's Avatar
    Download 'Light Flow'. You can set any app for notifications and multiple colors also.
    Morty2264 likes this.
    09-21-2018 12:27 PM
  6. Morty2264's Avatar
    Light Flow is a good app! I've heard some good things about it!
    09-21-2018 12:54 PM
  7. flever's Avatar
    Thanks for that idea. At the mean time I also wonder if it's hardware issue causing the built-in Email app not blinking, as the support person said. Can you tell if your built-in Email app does or doesn't blink?
    09-21-2018 02:50 PM
  8. johnts's Avatar
    My phone did not come with a built in email app. I think VZ removed it from their version.
    Carmen Rod likes this.
    09-23-2018 12:40 PM
  9. flever's Avatar
    Anyone else has the built-in Email app? can advise the notification LED function?
    10-03-2018 01:12 PM
  10. sushiguy732's Avatar
    Same here. Very annoying.
    10-04-2018 01:04 PM
  11. Carmen Rod's Avatar
    No built in mail app on mine either. VERY annoying.
    11-19-2018 12:42 PM
  1. Pixel XL no notification LED
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 09-21-2018, 02:02 AM
  2. Expanding Notifications on Huawei P20 Pro screen
    By dinsdale81 in forum Ask a Question
    Last Post: 09-17-2018, 12:21 PM
  3. Android Messages doesn't keep notifications
    Last Post: 09-13-2018, 12:36 PM
  4. Pixel XL no notification LED
    Last Post: 09-10-2018, 10:41 PM
  5. Turn off Messenger notification?
    By nthnu in forum Android Apps
    Last Post: 09-10-2018, 07:59 PM
