    At the moment, if a text popup appears I can either answer, wait for it to go away, or click the x in the top right corner. Unfortunately, as much as I like the popups, if I can't answer right away/am doing something else, I do not want to wait an undermined amount of time for it to go away on its own, but the x button marks the message as read so the notification goes away completely. Is there a way to change this so it is more similar to a Samsung where you can swipe away the notification without it removing it? For example, swiping away the popup like you can with notifications on the notification tray.
    04-11-2019 05:46 PM
  2. VidJunky's Avatar
    I'm not sure what app you're using but I had an app with pop-ups and swiping to one side, I don't remember which way was which, marked it as read and the other did not. I also had an app that had a setting for what to do with a message when x was pushed so you may also want to check your settings.
    04-11-2019 11:02 PM
  3. Laura Knotek's Avatar
    Welcome to Android Central.
    What messaging app are you using?
    I've used both Gboard and Textra. Both of those allow one to swipe away a notification without marking the message as read.
    04-11-2019 11:09 PM
  1. Replies: 1
    Last Post: 04-15-2019, 06:12 AM
  2. Replies: 2
    Last Post: 04-12-2019, 07:36 AM
  3. Spam Email Folder for Samsung S8 Plus
    By Michael Nathanson in forum Samsung Galaxy S8 & S8+
    Last Post: 04-11-2019, 05:25 PM
  4. What is the best android version for gaming and battery
    By Android Central Question in forum The Gamer's Lounge
    Last Post: 04-11-2019, 05:12 PM
  5. Replies: 0
    Last Post: 04-11-2019, 04:34 PM
