1. M3Fit's Avatar
    Hi guys,
    I've got this phone LG G7 quite recently, and got this problem right away.
    When I plug in my earphones with microphone included I'd say that 80% of the time, people can't hear my voice. They do hear a high-pitch sound, going over my voice. This happens on call, while recording audio, on what's app...
    So my guess is that's a jack-connection issue. I don't have another pair of earphones or external mic to try with at that time. But I was wondering if this was a common trouble? Should I look into getting other earbuds or look into fixing the phone?
    Thank you
    12-02-2019 11:06 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What brand and model earphones do you have? Are they specifically "Made for iPhone"? If so, those may not be entirely compatible, since iPhones use a slightly different headphone jack configuration.
    12-02-2019 11:13 AM
  3. M3Fit's Avatar
    Hi There,
    It is an independant brand - Symphonized. They were working with my previous phone - Samsung A5, until I couldn't use them on my phone anymore. So it really makes me think the problem is with the phone's jack connector.
    12-02-2019 01:27 PM
  4. Rukbat's Avatar
    The A5 jack went bad, then the G7 went bad? The thing common to both of them is the earphone/mic, so I'd bet on that being the problem.
    12-02-2019 06:01 PM
  5. M3Fit's Avatar
    Good point actually. But regarding the A5, It had water damage.
    But it is to consider indeed.
    12-02-2019 07:09 PM
  6. B. Diddy's Avatar
    First, make sure the headphone jack is clear of any debris by blowing it out with a can of compressed air, and rooting around with a toothpick. When you're sure it's clean, plug the earphones in again and make sure they're pushed in as far as they can go, since a slight discrepancy in the location of the contacts on the plug can result in problems.
    12-02-2019 09:21 PM
  7. M3Fit's Avatar
    I've done all this, but the problem still occur. I've enquired with owners of same earphone if they've experienced this. But I was curious about the owners of LG G7.
    12-03-2019 05:33 PM
  1. The person on the other side can't hear me when phoning them
    Last Post: 12-02-2019, 06:02 PM
  2. Replies: 4
    Last Post: 12-02-2019, 03:22 PM
  3. Replies: 0
    Last Post: 12-02-2019, 04:53 AM
  4. Why is my watch showing black and white
    Last Post: 12-01-2019, 07:54 PM
