Is anyone else noticing Phone Idle is draining an inordinate amount of battery? It seems like it's only been going on for a few weeks. It's pretty consistently using 30+% daily, and is always the top of the list. Tried restarting, no change.
Do you use the "Smart Cleaning" LG app? I use it once a week to clear out crap that may be causing issues.
I will try that. Thanks.
