1. pazzo02's Avatar
    Is anyone else noticing Phone Idle is draining an inordinate amount of battery? It seems like it's only been going on for a few weeks. It's pretty consistently using 30+% daily, and is always the top of the list. Tried restarting, no change.
    06-09-2019 12:58 PM
  2. thunder18's Avatar
    It does seem to amount to nearly 2% per hour.
    06-09-2019 05:15 PM
  3. Morty2264's Avatar
    Hmm, that's strange. Perhaps the battery is still taking time to adjust to usage patterns? It'd be helpful to see other users' SOT and standby time to compare.
    06-09-2019 10:03 PM
  4. OhAlfie's Avatar
    Do you use the "Smart Cleaning" LG app? I use it once a week to clear out crap that may be causing issues.
    Morty2264 likes this.
    06-10-2019 09:05 AM
  5. Morty2264's Avatar
    That's a really good idea!
    06-10-2019 01:12 PM
  6. pazzo02's Avatar
    I will try that. Thanks.
    06-15-2019 05:11 PM
  7. pazzo02's Avatar
    Just an update - the Smart Cleaning app did not solve the battery drain.
    06-19-2019 01:43 PM
  8. thunder18's Avatar
    I feel like standby time has stabilized and increased significantly over the last couple of weeks.
    06-19-2019 09:25 PM
  9. thunder18's Avatar
    Ridiculous battery life yesterday. Check out that screen on time.
    10-16-2019 08:38 PM
  10. OhAlfie's Avatar
    Good lord, you're staring at your phone for 8+ hours in less than one day!!?? No wonder battery is draining.
    10-21-2019 01:43 PM
  11. thunder18's Avatar
    Yeah, terrible I know. Not even sure how that happened.
    10-27-2019 09:14 PM
  1. Media recovery and rooting my phone
    Last Post: 06-11-2019, 01:53 PM
  2. Why samdung goes not add WiFi calling on all phones
    Last Post: 06-09-2019, 01:03 PM
  3. Phone switches off At any percentage
    By Rashidu in forum Ask a Question
    Last Post: 06-09-2019, 03:24 AM
  4. Phone battery problem
    Last Post: 06-09-2019, 03:02 AM
  5. When will my pre ordered phone be delivered?
    Last Post: 06-09-2019, 01:46 AM
