1. AC Question's Avatar
    My LG Leon was rooted and I tried to perform a factory reset, the problem is that it's stuck on the checking for updates screen. Is there any way possible for me to fix this or is it essentially soft bricked?
    02-03-2016 05:05 PM
  2. tube517's Avatar
    Did you factory reset in settings or in recovery? Did you have a custom recovery?
    02-03-2016 07:22 PM
  3. ruckusrick's Avatar
    I used he factory rest in settings
    02-06-2016 04:22 PM
  4. tube517's Avatar
    Do you have a nandroid backup? Custom recovery?
    03-05-2016 08:22 AM
  5. Joshe Bass's Avatar
    Im having a similar problem with my LG Power and after reseting my phone I havent been able to get past the "Just a sec..." screen. Is there a fix for this?, If so please help. Thank you.
    10-23-2016 06:25 PM
  1. Replies: 2
    Last Post: 06-18-2016, 12:23 PM
  2. Why won't my S5 update after factory reset?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-02-2016, 03:42 PM
  3. Replies: 1
    Last Post: 02-04-2016, 01:13 PM
  4. Replies: 1
    Last Post: 02-04-2016, 01:08 PM
  5. Car radio won't work after bluetooth pairing with Galaxy S4 mini, why?
    By AC Question in forum Samsung Galaxy S4 Mini
    Last Post: 02-03-2016, 01:30 PM
