1. anonimo antonio's Avatar
    Im having a problem with my smartphone, when I press the power button to awake the cellphone and put my pattern password, the screen stays completely black and starts to flicker on and off. This goes for some time and eventually it goes back to normal. After some minutes using it it starts doing it again, the screen goes on and off. The touchscreen is Not damaged because when the phone is intermittent I can put my pattern password and the phone unlocks, and use the phone "blindly", so it has nothing to do with that.
    Can it be the LCD that has been damaged? Can it be the "board"?
    please help!!!
    Running 4.0.3
    If you need any more details about the problem let me know! I will be online.
    09-29-2013 07:00 PM
  2. Gekko's Avatar
    it sounds like a hardware problem - perhaps not a bad LCD but the connection to the LCD. impossible to know without a complete evaluation by an engineer. i would try to get a replacement under warranty if possible. it may be time for a new phone.
    good luck!
    09-29-2013 07:55 PM
  3. anonimo antonio's Avatar
    good luck!
    Thanks for your answer Gekko!
    I already left it at a store and they evaluated the problem. They say it might be the LCD, but what you say makes more sense because the screen functions properly when it is not flikering on and off
    Can you direct me to any kind of post or website where someone is dealing or has dealt with this same problem?
    Thanks in advance!
    09-29-2013 08:01 PM
  1. Location service icons in status bar
    By shadowsjc in forum Verizon LG G2
    Last Post: 10-05-2013, 05:53 PM
  2. VRUAME7 Rooted and Encrypted S4 Stuck On Verizon Boot Screen
    By SamsungS4VRUAME7 in forum Verizon Samsung Galaxy S4
    Last Post: 10-01-2013, 01:40 PM
  3. Problems with screen when tilting?
    By emme64 in forum Samsung Galaxy S3
    Last Post: 09-30-2013, 10:25 AM
  4. Is there something from Android that syncs devices like the iCloud?
    By cynicalsloth in forum Verizon Samsung Galaxy S4
    Last Post: 09-29-2013, 06:54 PM
  5. New to android
    By Philip Willan in forum Samsung Galaxy Note 3
    Last Post: 09-29-2013, 05:36 PM
