I guess I'll post here because I think the Optimus Black is closest to what I have, which is the LG Optimus Bright, sold by NTT Docomo in Japan.
I bought it over a year ago for web app testing, no carrier contract, just wi-fi use. It had been working fine until the other day.
After recharging the 4 GB microSD card reports as damaged, so I removed it.
The main problem is that even though I can connect to my home wi-fi:
Status: Connected
Signal strength: Excellent
Link speed: 64 Mbps
if I try to go anywhere I get a network error. So YouTube, the browser, etc., all don't work.
I rebooted, but can't think of anything else to try. It is currently running 2.3.3, which I think is the highest possible for this device.
Is the problem related to the failed SD card?
Should I try a re-initialize to factory settings? If so, how do I do that?
Thanks,
doug
Status: Connected
Link speed: 64 Mbps
Thanks,
doug
