1. douglerner's Avatar
    I guess I'll post here because I think the Optimus Black is closest to what I have, which is the LG Optimus Bright, sold by NTT Docomo in Japan.
    I bought it over a year ago for web app testing, no carrier contract, just wi-fi use. It had been working fine until the other day.
    After recharging the 4 GB microSD card reports as damaged, so I removed it.
    The main problem is that even though I can connect to my home wi-fi:
    Status: Connected
    Signal strength: Excellent
    Link speed: 64 Mbps
    if I try to go anywhere I get a network error. So YouTube, the browser, etc., all don't work.
    I rebooted, but can't think of anything else to try. It is currently running 2.3.3, which I think is the highest possible for this device.
    Is the problem related to the failed SD card?
    Should I try a re-initialize to factory settings? If so, how do I do that?
    Thanks,
    doug
    09-03-2013 10:01 PM
  2. B. Diddy's Avatar
    I can't imagine a failing SD card would prevent you from connecting to wifi. Try the following, if you haven't already:
    1. On your phone, select your wifi network and "Forget" it. Then reconnect, enter the password, and see if that work.
    2. Reboot your router--unplug the power for 10 seconds, then plug it back in and wait 20-30 seconds for the connection to reestablish.
    09-03-2013 10:06 PM
  3. douglerner's Avatar
    The router is ok, I believe, because my computer, Nexus 7, iPhone and iPad all connect fine.
    I did what you suggested about the network. Nothing changed, but I did notice that the BROWSER is working and I can connect to web sites. The USA Today app is also working. But YouTube, Gmail and Evernote give "no network" errors.
    I wonder what is happening. Could the apps with connection fails need some info that is on the damaged SD card?
    doug
    09-03-2013 10:37 PM
  4. B. Diddy's Avatar
    I doubt that the apps would need something on the SD card, because they shouldn't store anything there. It wouldn't be good design for an app to store crucial info on a removable piece of memory. If you haven't tried, it is still worth rebooting the router, even though your other devices work. It's happened to me before where one device selectively can't seem to connect.
    09-03-2013 10:46 PM
  5. douglerner's Avatar
    OK. I just rebooted the router. Still the same.
    I don't know if the info on the memory card is crucial for the apps, but it does include files like:
    com.dropbox.android
    com.evernote
    com.google.android.youtube
    etc. Also, if I try to start DropBox it warns that it won't work right with the card.
    The Play Market is also not working.
    doug
    09-03-2013 10:54 PM
  6. B. Diddy's Avatar
    Hmm, interesting. Well in that case, consider the advice I gave in your other post, about copying all of those files over to your computer, reformatting your SD, copying the files back to the SD, and reinserting into your phone. You might also want to get a new SD card, because these things can start to fail over time.
    09-03-2013 11:01 PM
  7. douglerner's Avatar
    This was fixed in this thread:
    http://forums.androidcentral.com/lg-...ont-think.html
    The problem was indeed something that went wrong with the SD card. Reformatting the card fixed everything. And nothing was lost.
    doug
    B. Diddy likes this.
    09-05-2013 12:21 AM
  1. Replies: 33
    Last Post: 12-21-2018, 09:16 PM
  2. My Messages Are Messed Up?
    By nickoleye in forum Samsung Galaxy 3
    Last Post: 09-04-2013, 03:41 PM
  3. Replies: 3
    Last Post: 09-04-2013, 09:01 AM
  4. Weird situation with my s3's unlock status
    By gunner786 in forum Samsung Galaxy SIII I9300
    Last Post: 09-03-2013, 08:15 PM
