05-10-2016 11:47 PM
198 ... 678
tools
  1. Shante1105's Avatar
    Did you ever figure out how to change clock on the lock screen? I also have LG optimus g pro and don't see options for clocks and shortcuts. Just had update to 4.4.2
    06-03-2014 06:35 PM
  2. limitbreak09's Avatar
    I cant change it either.. I guess they removed that option
    06-03-2014 09:03 PM
  3. bobsrmt's Avatar
    sorry if this has been asked/answered but how do I get "press and hold this screen to add more content" of the screen. I don't want to add icons to the screen-just want it blank besides the bottom icons
    07-03-2014 09:01 PM
  4. Ju Victor's Avatar
    Why after i update to 4.4.2 i can't open my home
    07-04-2014 06:06 AM
  5. Lydia Kaply's Avatar
    For some reason, my Touch Keys light up, but they aren't working. They are being used to click on the next closest button to the top, how can I turn them back on? I've been through every setting in my phone and can't seem to figure it out.
    Thank you!
    07-10-2014 10:34 AM
  6. ajw79097's Avatar
    Quick question! I have been having trouble taking a screenshot via normal routes (power button/volume down OR pwr button/home button). After I updated to 4.4.2 is when it all started. I even downloaded a screenshot app, but that didn't work either. Can I change the way I take a screenshot or do any of y'all have a suggestion? Thanks!
    07-16-2014 12:53 PM
  7. npaladin-2000's Avatar
    Why not just use QuickMemo?
    07-16-2014 01:27 PM
  8. fjord's Avatar
    I love my optimus g but there is one thing i can't figure out. How can i turn off email notifications? I actually like the email syncing but I have to have my phone on constant silence with no vibration otherwise it rongs or shakes every 10~30 minutes because a notification of new emails pops up.
    Really, i just want that notification to go away permanently and no youtube video or other forum has been able to help. Please help.
    08-06-2014 11:32 AM
  9. fjord's Avatar
    For clarification, under both the email and notifications settings i already have notifications turned off. I don't have a gmail app installed, just the email client native to the phone.
    08-06-2014 11:50 AM
  10. hawkwind212's Avatar
    Go into the setting section of your email app. Look for an option that has the word notification in it, when you find it, uncheck the option, and restart the app. That's about as simple of method as I can tell you since i don't know what stock phone app you're using. If it gets more complicate than that, post another message and I will try to help.
    Sent from my LG-E980 using Tapatalk
    08-07-2014 02:17 AM
  11. George44's Avatar
    I have a new LG Optimus G Pro that I am quite pleased with except for one little minor problem. When I get a phone call, the correct screen comes up and tells me to swipe the green button which I do, but it will not answer the call. I tap the green button and it ignores that also. This screen has three options as you are probably aware. Any suggestions regarding settings or something else that might be wrong. Everything else works perfectly. I receive and send text; receive and send email; and search the internet without problems. My carrier is ATT. Any suggestions would be appreciated.
    08-26-2014 05:19 PM
  12. Brad Steele's Avatar
    Try swiping diagonally (starting with finger on green circle) towards the top right corner of the screen.
    Lg0Gpro_2_AC
    08-27-2014 02:33 AM
  13. Jessica Comage's Avatar
    Post a screen shot of yours. That will help
    Sent from my LG-E980 using Tapatalk 2
    09-30-2014 12:30 AM
  14. Jessica Comage's Avatar
    content://media/external/file/5408
    09-30-2014 12:34 AM
  15. Jessica Comage's Avatar
    Why can't I change my clocks on my lock screen all I have a option of is shortcuts
    09-30-2014 12:35 AM
  16. Brad Steele's Avatar
    Welcome to our plight.
    Me 2 you via Lg0gPro
    01-02-2015 06:37 PM
  17. Juan Castro4's Avatar
    You have to do it through the widgets settings. On the lock screen. But I think you only get the weather clock and world clock.
    01-27-2015 01:58 PM
  18. guitarboy0211's Avatar
    Hey, can anyone help me to uninstall or remove the 2nd-init recovery that I installed from the freegee app? Its wrecked my phone and I cannot mount my sd card any longer and the phone's functions are a bit distorted now.
    02-25-2015 08:59 AM
  19. hawkwind212's Avatar
    What did you do with freegee exactly? I don't understand what you mean by the 2nd-init recovery you installed.
    Using LG-E980 with Tapatalk
    02-26-2015 01:38 AM
  20. guitarboy0211's Avatar
    Heyy! Sorry for the late reply. I was out of town. Anyway, the thing is, I downloaded freegee and it showed my aboot is not supported but nonetheless I went ahead with the installation and went with Cwm recovery. Since then it has installed or idk placed a file named '2nd-init' in my system. Since then my phone is no longer able to mount my sd card. It shows inserted but does not mount. Its not an sd card prob because that same one works with other phones. Any idea or help?
    03-26-2015 07:01 AM
  21. Akosua Achiaa's Avatar
    please how cam my lg optimus g pro do not have camera screen mode in it setting,
    09-17-2015 01:00 PM
  22. Sabrina N Michael's Avatar
    My LG e980 screen always goes black while making phone calls making it impossible to end call put on speaker or us the touch tone key pad how do I fix this
    05-10-2016 11:30 PM
  23. hawkwind212's Avatar
    You need to provide more spec info for your e980. I.E. what kind of ROM you're running, stock or custom? Which version(kk or lp), and which dev(cm, bliss, etc...)
    05-10-2016 11:47 PM
198 ... 678
  1. Replies: 4
    Last Post: 05-01-2013, 09:49 PM
  2. Have questions about the Aria? Ask 'em here
    By Phil Nickinson in forum HTC Aria
    Last Post: 04-10-2013, 11:57 AM
  3. Why aren't people talking about the LG optimus G pro?
    By inthegalaxy in forum General News & Discussion
    Last Post: 03-22-2013, 03:33 AM
  4. Questions about the installation of Android ASK
    By caiyan1990 in forum Virgin Mobile Optimus V
    Last Post: 05-24-2011, 02:40 PM
  5. What's everyone think about the LG Optimus 2X?
    By Sean Brunett in forum International Optimus 2X
    Last Post: 01-13-2011, 02:50 PM
