How to manually clear usage statistics & reset to zero?
May 29, 2013
14
Has anyone figured out a way to manually clear usage statistics for voice and data, and reset the counters to zero? On the iphone this was accomplished easily in the settings. I don't find the options available on the OGP.
All I have found by googling the topic are a few other threads that mention the carrier does it automatically at the start of a billing cycle. But, since I am using this phone on prepaid, I have no billing cycle. In the past I just kept track manually by zeroing it out every time I add minutes/data and would like to be able to do it on the OGP.
If someone knows how to do this, it would be very helpful. If not, then I'll stop into the AT&T store on Monday and ask their technician.
Thanks in advance.
natehoy
2,667
71
Go into the usage screen and set the day of the month to reset statistics to the day you want.
Or, of course, a factory reset.
There may be other ways but those are the two I see.
Sent from my LG-E980 using AC Forums mobile app
bnutz
