1. ajarnfalang's Avatar
    Is this mode to decrease the brightness and processor speed ALL the time? or only when the battery falls under a certain %?
    Also, does it really make a difference?
    And how about the "Quad Core Control"? Is this something you turn on? Or is this just how the phone works?
    08-24-2013 08:58 PM
  2. ajarnfalang's Avatar
    Just checked the phone at the store. Ok. So they both have on/off. I still wonder how the Quad Core Control works. Does it turn off cores when not in use and then turn on when you're playing games, etc?
    08-25-2013 12:16 AM
  3. metle_geek's Avatar
    Basically throttles the cpu down and it depends on the dev or oem it helps keep the screen brightness low it can turn off the wifi when off idk
    Sent from my HTC One X+ using AC Forums mobile app
    08-25-2013 12:18 AM
  4. ajarnfalang's Avatar
    What if an app needs full power? Will it allow the CPU speed to go up and down dynamically?
    08-25-2013 12:36 AM
  5. metle_geek's Avatar
    Like i said it depends on the dev or oem
    08-26-2013 05:36 AM
  1. Power button repair *please help*
    By Kevin Hutcheson in forum HTC EVO 4G LTE
    Last Post: 09-22-2013, 03:54 PM
  2. Replies: 1
    Last Post: 09-02-2013, 06:02 AM
  3. How do I get better battery life? I am asking 13 hours on medium use
    By jaybro0813 in forum Verizon Samsung Galaxy S4
    Last Post: 08-25-2013, 12:02 PM
  4. Does anyone have the nexus LW apk?
    By cporier91 in forum Wallpapers, Ringtones, and Themes
    Last Post: 08-24-2013, 08:10 PM
  5. Nexus 4 does not "lock" when display shuts down automatically
    By CaptainNexis in forum Google Nexus 4
    Last Post: 08-24-2013, 04:44 PM
