1. purefire231's Avatar
    Hey guys!
    I have been a Lg Optimus G Pro ovner for 2 days now and I have encountered a problem with the screen. The phone seems to work really good in general but sometimes my screen goes `crazy` and it looks like a invisible hand is tapping around. With out me touching the screen the lg opens and closes aps, or writes letters in my sms. Then I tested this with the quick memo. I was drawing circles and all of a suden the lg starts doing straight lines all by itself. It also locks me out at that time and I cant press or do anything except lock the screen and than unlock it. I scaned my phone with Lookout but found no malware whatsoever and I reset it completely but the problem still remains. Does anyone have any ideas to what might be wrong or have any solutions?
    Thanks
    08-25-2013 10:30 AM
  2. Kilroy13's Avatar
    You may need to perform an exorcism!
    Sent from my HTCONE using Tapatalk 4
    08-25-2013 10:53 AM
  3. purefire231's Avatar
    Haha yes I was thinking the same xD but besides that I dont know what to do...
    08-25-2013 11:11 AM
  4. ajarnfalang's Avatar
    Hey guys!
    Thanks
    People are just going to say to take it back.
    Just take it back to where you bought it. Short of wiping the phone clean first, there's little you can do. May be a hardware issue.
    08-25-2013 02:38 PM
  5. purefire231's Avatar
    Yes I am taking it back tomorrow...Its really wierd and unlucky since i haven`t read anywhere about a similar problem with this phone...
    08-25-2013 02:42 PM
  6. purefire231's Avatar
    Thanks for the replay though your phone is okay for you?
    - - - Updated - - -
    08-25-2013 03:01 PM
  7. excalis's Avatar
    Could be an overheating issue, when I was in Chicago the humid heat there was causing my phone to do the same thing, or at least that is what I decided the cause was. It has not had any of that behavior since I have been keeping an eye on the device temp. It had the same type of problems you described.
    08-26-2013 12:45 PM
  1. How to turn vibrate off on notification screen?
    By maverick96 in forum Moto X
    Last Post: 06-28-2014, 08:06 AM
  2. Anyone using Smart cover without the wake timeout problem ?
    By prowede in forum Google Nexus 7 (2013) Accessories
    Last Post: 08-26-2013, 11:17 AM
  3. Problem with Wi-Fi
    By gewdax in forum Samsung Galaxy S4 Google Edition
    Last Post: 08-25-2013, 05:33 PM
  4. Let's see your home screens
    By Connor Milligan in forum HTC One M7
    Last Post: 08-25-2013, 11:42 AM
  5. Zombie Screen Shootout
    By zarcrash in forum Android Games
    Last Post: 08-25-2013, 03:47 AM
