1. Melvin Chong's Avatar
    Any way to voodoo it like the Galaxy S ?
    09-13-2013 06:07 AM
  2. fabe#AC's Avatar
    Install speaker booster free version...works really well to increase the volume on everything
    https://play.google.com/store/apps/d...i.SpeakerBoost
    Enviado desde mi LG-E980 usando Tapatalk 2
    09-13-2013 08:36 AM
  3. Melvin Chong's Avatar
    Thanks for tje reply. Will try it out ☺
    09-17-2013 05:52 AM
  4. Melvin Chong's Avatar
    Doesn't work on the G pro at all. Bummer.
    09-17-2013 05:56 AM
  5. penningtonsm's Avatar
    Works on my G Pro just fine. Doesn't make it much louder, but you can definitely hear a difference when you change the EQ settings.
    Sent from my LG-E980 using AC Forums mobile app
    09-17-2013 08:33 AM
  6. fabe#AC's Avatar
    Go to settings and choose maximum allowed boost and choose 100%
    Uncheck non-uniform boost. .
    You will hear the difference...
    09-17-2013 08:44 AM
  7. penningtonsm's Avatar
    Thanks a lot. Huge difference!!
    09-17-2013 01:06 PM
  8. dave0813's Avatar
    I checked sound settings and was unable to find uniform boost. Can you explain where to find, sorry new to Android.
    09-19-2013 08:32 AM
  9. fabe#AC's Avatar
    Here is how it looks like...
    09-19-2013 11:06 AM
  10. dave0813's Avatar
    http://img.tapatalk.com/d/13/09/20/pude4ymu.jpg
    Thanks for the screen shot, but I have checked every settings Menu and I do not see this list. Can you list list the steps? This was not under the four tabbed lists (Networks, Sound, Display or General). I have an At&t LG version of the G Pro.
    09-19-2013 11:14 AM
  11. penningtonsm's Avatar
    He's talking about the settings on the app, not your phone. Open the app, then hit the menu tab. That's where you will find it.
    09-19-2013 03:23 PM
  12. fabe#AC's Avatar
    Not man it's an app...check post #2 I left the link to playstore
    09-19-2013 04:46 PM
  13. dave0813's Avatar
    Thank you, I am good now.
    09-19-2013 11:12 PM
  14. Stephen Kwan's Avatar
    I noticed the app gives a warning saying high boosts can potentially damage the speakers, is this something we should be worried about or is it just a very mild precaution?
    10-24-2013 07:09 PM
  15. nbi1's Avatar
    Doesn't work. Attempting to increase volume just distorts the audio without increasing the volume. That's the typical failure mode for these apps. Or it simply doesn't do anything.
    10-20-2015 01:54 AM
  1. Wifi on Huawei G510 not working
    By Merel van der Meer in forum Huawei
    Last Post: 09-13-2013, 03:14 AM
