Same thing happening on mine I noticed it about 2 days ago I did a factory reset and the problem still persist.��
Clean Master from KS Mobile was the culprit. Reinstalling all of my apps, Clean Master said it was incompatible with my Android version. I went online, downloaded the beta version and the problem popped up again. Uninstalled and problem fixed.
Hi, I live in India but I have bought my AT&T locked LG Optimus G Pro E 980 from USA in July 2013 and got it unlocked in India. Now I am using it on Vodafone network and it is working extremely fine.
I came to know that AT&T has realsed some value pack update for this phone and when I tried to download it from Software udate option, the message says - You are not registered yet.
Is there any way that I can get this update? I also read today on internet that net update of 4.4 kitkat is also likely to come for this phone by Q2 end. So, would I be able to update it then?
I have got my phone rooted today and if this could anyhow help me, do let me know. Thanks.
What is the difference between factory reset and hard system reset ?
