1. AC Question's Avatar
    Why won't my messages send on my LG OPTIMUS G PRO AT&T after software update TO 4.4.1?
    I get an alert "Message not sent". whether I use AT&T SMS Messages or Messaging. Please help!
    I can receive messages but can't send.
    04-01-2015 01:49 PM
  2. itguyjax8430's Avatar
    You can try going in and resetting your APN settings.
    Restore default APN settings
    Note: You need to have previously added an APN to access the reset feature.
    From any Home screen, tap the Menu key.
    Tap System settings.
    Scroll down to 'CONNECTIVITY,' and then tap Tethering & Networks.
    Scroll down to 'NETWORK ,' and then tap Mobile networks.
    Tap Access point names.
    Tap the Menu key, and then tap Reset to default.
    Note: A seperate APN must be added manually for the Reset to default option to appear.
    Tap Yes.
    04-01-2015 03:28 PM
  3. Rukbat's Avatar
    Texts don't use the APN.
    If you haven't gotten this straightened out yet, bring the phone to your AT&T Device Support Center (ask at your local store where the nearest DSC is), and ask them if they can please fix the update for you. The G Pro I'm working on at the moment got 20h (4.4.2) and still sends texts with no problem.
    04-12-2015 05:04 PM
  1. Why system apps can recover data?
    By Claude Speed in forum Ask a Question
    Last Post: 07-05-2015, 03:36 AM
  2. How do I get android tablet to use an external sd card?
    Last Post: 04-02-2015, 12:51 AM
  3. How do I get pictures off of my phone?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-02-2015, 12:40 AM
  4. Why am I unable to connect to my college wifi?
    By AmazingManOfSteel in forum Ask a Question
    Last Post: 04-01-2015, 06:38 PM
  5. contact profile pic different to their pic in messages
    By stringjunior in forum Sony Xperia Z3 Compact
    Last Post: 04-01-2015, 02:40 PM
