Save big + get 3 months free! Sign up for ExpressVPN today
  1. vgking96's Avatar
    As of the past few days, I have noticed an increase in time needed to charge fully, from dead (from roughly 2 hours to over 4 hours) and also a decrease in the ability to maintain the charge.
    From unplugging, I was down to 78% after one hour of very minimal use (One phone call and a quick check of the home screen).
    I took a screencap of my battery stats, if this can offer any insight.
    The massive drain from SD memory is worrying.
    Thanks.
    Sent from my LG-E970 using AC Forums mobile app
    09-06-2013 08:46 AM
  2. D13H4RD2L1V3's Avatar
    Thanks.
    Have you tried other battery apps that give a lil' more detail on what's sucking your battery?
    09-06-2013 09:02 AM
  3. SpookDroid's Avatar
    Check your SD Card, it may be damaged. If the card unmounts/remounts itself randomly, the system 'scans' the card for errors every time it remounts, and the more files you have, the more time it spends scanning... This, of course, drains your battery like crazy.
    ETR174 likes this.
    09-06-2013 09:59 AM
  1. Best external battery?
    By Eclipse2K in forum Motorola Droid MAXX
    Last Post: 10-12-2013, 06:24 AM
  2. Battery loop on re charge???
    By racermech in forum Samsung Galaxy Tab 7-inch
    Last Post: 09-06-2013, 08:01 PM
  3. Google Services - Battery
    By joshsparham in forum Sprint Galaxy S III
    Last Post: 09-06-2013, 07:13 PM
  4. Battery Brag Thread
    By israelkendall in forum Motorola Droid MAXX
    Last Post: 09-05-2013, 06:47 PM
  5. Screen time and battery life
    By dad2paisley in forum HTC One M7
    Last Post: 09-05-2013, 05:30 PM
