A
AC Question
LG Optimus G - Doesn't charge unless I unplug/replug battery
Hi!
I have a strange issue with my LG Optimus G after I have replaced the screen. After using the phone for a while I cannot charge the phone anymore. When I plug in the cable it says "Charging" on the lock-screen, but it doesn't show the lightning where the battery is and the battery percentage is not increasing. It's like it does not go into charge mode properly.
If I remove the battery connector and plugs it in again it works. Like something resets which leads me to think the issue could be software related?
I am running the latest Android 4.4 and I have of course tried several chargers and cables.
Kind regards,
Brian
Hi!
Kind regards,
Brian
