USE THIS RECOVERY OR ROM WONT FLASH
http://forums.androidcentral.com/showthread.php?t=179604
XIONIA will work too!!!
hello all first i want to say before we get started this is a port of a port
next i will not be working on this all the time but often because this will just be synced with zakman's build and try to work out possible problems so wish me luck
next i have not tested so dont know if it boots but it should
next it has the quattrimus kernel until i can unpack boot.img and include the kravens kernel(Go flash the 15th one its faster)
I'm not responsible for brickings
Lets get started
this is zakman's rom so it has ALL features as the v one i just switched a couple files so it works i used no base so did not need permission for rom bases
This is cm10 not cm9 or cm7 or anything else its cm10 so only discuss this not anything else.
fixes or help with the rom Would be greatly appreciated
also no jellybean goodies YET
what works
phone
sms (sending and getting)
gps
wi-fi
3g
sound (speaker and headphones)
all the basics but theres more that works
Google Now
Google ears
Theme engine
what doesnt work
mms
rest of the issues are not noticeable so not much problems
Download rom-https://www.dropbox.com/s/xovdeaaud5uz9vm/CM10-ALPHA-6.zip
Zakmans gapps fixed Google ears- http://www.mediafire.com/?iqd5hvyr33omf7x FLASH THESE GAPPS FOR BETTER APP COMPATIBILITY
zakman's thread-http://forums.androidcentral.com/op...198058-rom-wip-cm10-port-jelly-optimus-v.html
Changelog
8-9-12 initial release
8-10-12 fixed sdcard moving problem see instructions after this
8-12-12 added amphetimes, replaced a lib file that zakman replaced (Will say what it is in a minute i forgot),signed
8-14-12 added a better launcher apex
8-21-12 Better launcher (Stock Trebucket jellybean launcher modded), Bobzhome kernel (Much Faster), Google now fixed mostly,Audio files fixed,Better GPS for improved acuracy,Better app Compatibility (ics compatibility i think),Theme chooser (not working yet), new RIL files added better reliability,Youtube app i think,Build.prop changes (WOOT WOOT BIG UPDATE)
Fix Google Now
1.Flash Rom
2.Flash Gapps that i posted not my old ones or other old ones
3. install this-http://www.mediafire.com/?59yugc7w8jdoxy0
4. install this-http://www.mediafire.com/?vyadrtddrjb2d4j
5.Profit
do not move apps manually to sdcard let the scripts do it
also every time you flash this rom if you had apps they will be there due to scripts
You must have a 512 mb ext3 or ext4 partition for this ROM to work properly i prefer 1gb
i recommend Apex Launcher its MUCH more smoother sorry didn't include will re-include in next build.....
SCREENSHOTS!!!
Lets get started
HOW TO FLASH
1.use pre flash wipe in drews recovery or just wipe all if in a different one
2.disable signature verification
3.flash rom
4.flash gapps
5.boot android
6.profit
3.flash rom
4.flash gapps
5.boot android
6.profit
what works
phone
gps
wi-fi
3g
Google Now
Google ears
Theme engine
what doesnt work
mms
Issues-
1.when apps are moved to sdcard they are uninstalled so dont move apps to sd card
3.any downloaded zip,apk or other files will not show up until reboot
5. Deep sleep
5. Deep sleep
thanks
torch2424- for inspiring me (YOU DA MAN)
zakman- for letting me port
TDM- kernel
Cyanogenmod-being awesome
android-for making jellybean
the first person who rooted the optimus s- for rooting it and making it so we can make good roms like this
Drew-For originally got cm10 booting on the optimus s
nitestalkr-apps2ext (THANK YOU)
TDM- kernel
Changelog
Fix Google Now
1.Flash Rom
5.Profit
SCREENSHOTS!!!
