In need of help remounting
the_maplebar
171
53
I assume you are trying to run these commands from the terminal
Code:
# mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
# cat /sdcard/flash_image > /system/bin/flash_image
# chmod 755 /system/bin/flash_image
# mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
# mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
# flash_image recovery /sdcard/xionia_cwma_12518.6.img
# reboot recovery
You need to enter su first to get a root terminal
Code:
# su
To make sure you are root enter
Code:
# whoami
whomami: unknown uid 0
uid 0 means you are root.
Reactions: mike9670
the_maplebar
171
53
oops, my bad. The links to whomai are part of the a custom rom. You can do
Code:
busybox whoami
You should have busybox installed it is part of the rooting instructions.
the_maplebar
171
53
I fixed the terminal command. You should have busybox installed. It's part of the rooting process when you use gingerbreak. Step 11 has you install busybox along with su
11) Copy su and busybox to /system/bin
cat su > /system/bin/su
cat busybox > /system/bin/busybox
cat Superuser.apk > /data/app/Superuser.apk
fallingOutOfLoveWfithTech
