1. BZOptimusS's Avatar
    I have this sweet new ROM I downloaded last night, and I'm stuck between going the route of installing GingerKernel, and using SETCPU, or using the colin_ph Battery Tweak..... any pros out there with some advice? I want a fast Optimus, But not a buggy one that reboots and hangs. Any advice would be wicked. Thanks all
    Specs:
    Custom Battery @ 5100 mAh 3.7 VDC L-Ion (will post a thread later on this, mind = blown)
    Xionia 1.2518.6 Custom Recovery Console
    gROM 2.3.3 with GingerKernel flashed for OC'ing
    .........currently hanging up @ 40% battery @ 806 MHz w/ SetCPU.
    I want more than 748. Plain and Simple.
    09-24-2011 12:01 PM
  2. mike9670's Avatar
    Do not use Gingerkernel. You will get wierd screen things. Does not work well with gROM
    09-24-2011 01:08 PM
  3. BZOptimusS's Avatar
    im noticing that.... the screens real buggy and wacks out and randomly selects stuff when i try to scroll or type. how would i go about reverting to Reborn ROM 2.2.3? or is there a more recommended path you or someone else may know of?
    09-24-2011 01:48 PM
  4. BZOptimusS's Avatar
    Can I flash VD baseband built ROMS, like reborn 2.2.3 (or 2.2.4) to a vzh radio?
    09-24-2011 01:58 PM
  5. im_electronic's Avatar
    Wait for the next gROM and stick with the current one till then. I i'm sure you won't be disappointed
    09-24-2011 01:59 PM
  6. BZOptimusS's Avatar
    i just dont know if i can deal with tourettes screen mode due to my dumb @$$ flashing gingerkernel. :/
    will the next release of gROM be OC'd? and less skittish?
    uurel23 likes this.
    09-24-2011 02:01 PM
  7. BZOptimusS's Avatar
    essentially what i want to do is either go back to 2.2 and use Reborn or some other ROM. or resolve this edginess of the 2.3.3 ROM. any ideas out there?
    again i have xionia 1.2518.6 and gROM 2.3.3 with gingerkernel..... how do i remove gingerkernel to start with?? id LOVE it if someone had that info.
    09-24-2011 02:21 PM
  8. mcasas's Avatar
    I did a dirty flash of grom to remove gingerkernel and havnt had any issuses since.
    BZOptimusS likes this.
    09-24-2011 02:45 PM
  9. BZOptimusS's Avatar
    dirty flash as in no wipes or resets?
    09-24-2011 02:48 PM
  10. mike9670's Avatar
    Do this to get rid of ginger kernel. Grom is working fine and updates are coming.
    09-24-2011 02:52 PM
  11. sfhub's Avatar
    Yes, gROM includes its own kernel/boot.img, so dirty flash will replace the one GingerKernel put in place.
    09-24-2011 02:53 PM
  12. BZOptimusS's Avatar
    Thank you both so much for your help Runs like clockwork now. with a few rusty gears but thats expected of a fresh ROM, I can't wait for the next in the gROM lineup to appear.
    09-24-2011 02:57 PM
  13. donbudafuko's Avatar
    What do you mean a custome battery
    09-24-2011 03:00 PM
  14. BZOptimusS's Avatar
    What do i mean? well whe i can post a thread with a picture, i'd love to show you. someone posted a review regarding the 3600 mAh extended optimus battery from china, well i got ghetto clever and decided to take that battery and hotwire the two lithium packs it has to the stock optimus S battery and its control board. so the battery still is recognized as the stock 1500 mAh but it totals in excess of 5000 mAh. i cant put a BACK* on the phone, but scotch tape helped a load. if you dont mind a 3/4 inch protrusion from your phones back then this mod is excellent for you overclockers and power users. I can get 40 hours of off and on heavy usage of the phone, from netflix, to music, to texting, to youtube to 4 hour phone calls. i can show you all how to make one if you're interested. it does take away from the aesthetic appeal of the phone. for sure.
    09-24-2011 03:12 PM
  15. donbudafuko's Avatar
    Sure would atless to look at an see what i would need to do it sounds like sone fun
    09-24-2011 03:21 PM
  16. BZOptimusS's Avatar
    It really is man. I get epic battery life, and stock charger only take an hour and a half longer to charge the battery.
    09-24-2011 04:01 PM
  17. donbudafuko's Avatar
    Nice can u put the link up wen u can woukd love to take a look at it
    09-24-2011 04:36 PM
  18. BZOptimusS's Avatar
    http://forums.androidcentral.com/lg-...-5100-mah.html
    Here All, this is it. The battery you superusers have been waiting for.
    09-24-2011 07:28 PM
