1. princedavey's Avatar
    I'm hoping someone can help. I was trying to unroot the phone and now the phone just boots to Clockworkmod recovery v3.2.0.1 and it wont let me restore to any previous backups. Any time I try to reboot, I get the Lg Splash screen and then it just sends me back to Clockworkmod. I am a noob, I am not very experienced but I am willing to try anything.
    My phone is recognized when I type adb devices in the cmd prompt but I have no clue what to do from there. I dont know how to manually flash a ROM, please help I really don't understand how I got to this point (I flashed my Nexus just fine) I have a Sprint LG Optimus S (Black) Purchased in January of 2011. It was previously running CM7 (I paid someone to do it).
    Edit: I'm also not very good with Forums so please bare with me. I appreciate any and all replies. Thank you!
    10-10-2011 11:52 AM
  2. Jessicalt1's Avatar
    10-10-2011 12:43 PM
  3. jcwxguy's Avatar
    clockworkmod recovery v3.2.0.1 Did use rom manager by chance? as long as you have adb access, your not perma-bricked ..Try the link above
    princedavey likes this.
    10-10-2011 01:05 PM
  4. princedavey's Avatar
    Yes, I used ROM manager. The links to the VC cab (I dont even know what that is) is broken everywhere I go. I am getting really desperate and I have even tried going through the KDZ route with no luck. The Lg mobile software update doesn't even list the phone (even though the instructions state that it will). Im just really lost, I feel like I got myself into something I can't get out of. Thank you for your help and your speedy reply.
    10-10-2011 11:38 PM
  5. sfhub's Avatar
    You can get the v8, v9, vc, vd cab files from reference section 9f of the ZVH rooting thread.
    I'm providing the link for you. Look in the reference section.
    http://forums.androidcentral.com/lg-...diag-mode.html
    10-11-2011 12:09 AM
  6. tlrsax54's Avatar
    Yes, I used ROM manager. .
    Just because it can never seem to be stated enough....Do NOT use ROM Manager on the Optimus S phones...it's a sticky for a reason, it doesn't work.
    10-11-2011 01:49 AM
  7. jondevere's Avatar
    Moving this thread to Rooting Roms and Hacks.
    10-11-2011 01:54 AM
  8. Jessicalt1's Avatar
    Are you on stock recovery or a custom recovery?
    10-11-2011 08:51 AM
  9. bblaze's Avatar
    Try this out. It was originally posted by Zefie, and it has fixed that issue with me. There should also be an option in Xionia recovery (if you are using that) to stop the boot loops as well. Should be in the advanced option from the main screen of the recovery. Hope that helps.
    Guys with the Custom Recovery Boot Loop:
    First off this is NOT a recovery image and do NOT flash it, follow the instructions provided!
    1) Download recovery.bin
    2) Extract file with 7zip or WinRAR or whatever.
    3) Open a command prompt to the same folder as where you placed extracted recovery.bin
    4) Run these adb commands
    adb push recovery.bin /rec
    adb shell chmod +x /rec
    adb shell /rec
    5) Now you should see LG's recovery menu. Simply hit "reboot" (first option).
    6) Boot loop should now be gone.
    Tech Details: LG has some funny voodoo going on and only their recovery can tell the phone to stop booting into recovery. This is why it says "do not remove the battery" on their recovery.
    10-11-2011 10:56 AM
  10. Jessicalt1's Avatar
    Any luck?
    10-12-2011 08:42 PM
  11. princedavey's Avatar
    The link you provided does not work. It takes me to a drop box error page. Thank you though.
    10-15-2011 03:09 AM
  12. princedavey's Avatar
    Nothing yet. I gave myself a few days off before I threw the dang thing out the window lol Im trying all of the different methods now. Hopefully something works.
    10-15-2011 03:10 AM
  13. princedavey's Avatar
    10-15-2011 03:28 AM
