agreed. I've been thinking about creating one large rooting-recov-rom-kernel-theme thread that includes definitions and explanations.Not to be pedantic either, but the stickies could use definitely use some attention. They are exceptionally fragmented and confusing for new folks at this point in terms of how to root and what's what. The web of estranged links is quite puzzling. Now, I'll be the first to e-smack somebody for using ROM Manager, but if they genuinely want to learn now, it has become much more difficult than it was before the ZVH fiasco.
I suggest that someone with the necessary privileges modify/consolidate the stickies so that it is more direct and allows noobs to determine what they have quickly, and presents them with the appropriate action options. Perhaps even a quick explanation of what a radio or baseband is, that custom recoveries do not mess with it, and how we have 2 working versions in play for this device? I hereby volunteer to help.
Pretend you are coming to this device section for the first time with your recently purchased ZVH device. Play dumb and try to figure out how to own that thing in your hand using this site. Good luck!
And now that Drew has graciously posted a new custom recovery option, someone who knows the difference should explain to those who don't what the difference is and make a recommendation or present the options to them. If all of the answers about a custom recovery or ROM are not apparent in the first 2-3 posts, then that thread is not maintained. I don't care if you just uploaded a new version 2 hours ago; if people can't figure out why they should/shouldn't use it, it is just a point of confusion.
Further, how the hell is it that we have a couple of automated WIndows tools to root a ZVH device, yet no manual way to root it using Linux?? Isn't this like telling a Mayan or an Egyptian that there is no sun, then handing him a digital watch and a bottle of Coppertone to further his understanding of the universe?
That does it then. I'm taking the lead on it and we'll sort it out. If folks want something else linked or added, I can always add it later. I would welcome your input.agreed. I've been thinking about creating one large rooting-recov-rom-kernel-theme thread that includes definitions and explanations.
Maybe If someone cannot figure out how to read through the stickies, half the time its because they are to lazy to do the research maybe they should not be messing with there phones programs. All the steps are there, all you have to do is read them and follow them. And then if you still have uncertainties ask questions. People here are always happy to help, we just ask that they take the time to read up first.Not to be pedantic either, but the stickies could use definitely use some attention. They are exceptionally fragmented and confusing for new folks at this point in terms of how to root and what's what. The web of estranged links is quite puzzling. Now, I'll be the first to e-smack somebody for using ROM Manager, but if they genuinely want to learn now, it has become much more difficult than it was before the ZVH fiasco.
I agree that one should have some initiative and desire to learn and take responsibility for their actions before they assume control of their device in ways that can either improve it or ruin it.Maybe If someone cannot figure out how to read through the stickies, half the time its because they are to lazy to do the research maybe they should not be messing with there phones programs. All the steps are there, all you have to do is read them and follow them. And then if you still have uncertainties ask questions. People here are always happy to help, we just ask that they take the time to read up first.
There are manual instructions. See reference section B in the 2nd post.Further, how the hell is it that we have a couple of automated WIndows tools to root a ZVH device, yet no manual way to root it using Linux??
If the 2 basebands you are talking about are ZVD and ZVH, the same rooting method works for both. It probably works on earlier versions too, but hasn't been tested.especially with two basebands--each with different rooting methods
two recovery options
1) connect your phone to your PC
2) download this file optiauto-sfx.exe, double-click and select Option A
There, done, rooted and custom recovery installed.
There is a known issue with hydroRom and apps. There is a fix for it a few pages back if you still have problems with the market
ok, still having the issue with the market, but other than that, AWESOME ROM,
I have read all 26 pages of the HydroROM thread 3 times, and even though I could swear that I seen the market update the other day, I cannot find any now, help please?
Post #78 hydro rom
Allright, lets try this mod and see if it helps with the reboot issues.<br />
<br />
Download and place on sd card.<br />
http://db.tt/eyXvV0hF (dalvik2dev-HydroRom.zip)<br />
<br />
-Install HydroRom beta and let it boot fully<br />
-Return to recovery, wipe cache and dalvik-cache<br />
-flash mod<br />
-Reboot and install apps<br />
<br />
NOTE: This will give you about 50 or so extra mb internal storage. It is similar to the dalvik2cache mod except fixes issues with market downloads/updates that users experienced in the past.<br />
<br />
Each reboot will take longer now because dalvik-cache is rebuilt everytime. <br />
<br />
On a personal note, I've got quite a bit to take care of in my personal life today, but please post your experience while testing this and I will try to check in once in awhile to see how its going.
I seen this post, but what does it have to do with the market fix?
this is the updated ROM zip that I have already flashed
Flash the MOD it will help
as well as moving dalvik cache it also has market fixes build in. Did you wipe cache/dalvik cache before flashing this mod?
