Re: [WIP][ROM]COLD AS ICE-CM9 Sprint LS670 2/20 ZVD basesband Alp
Per kraven's request...
I have put together a list of what works and doesn't work in alpha4.
This post might be rather long...
S-O-R-R-Y in advance..
What does work:
- Phone Calls
- 3G connections when you apply my patch in post #134.
- All sound modes, silent and vibrate, also.
- Alarms... 8:30 this morning..
- Updating apps via the Android Market... by the way, that works too.
- USB storage (that's kinda iffy)
- Gallery is now working... Camera isn't.
What doesn't work/Bugs
- As we discussed in posts 229 - 235, there are "rays" in the background of some apps and the screen, leaving "ray like" bursts of color. This is not a screen or pixel problem, because those are screenshots.
- Some bars, such as the ones in Music app, are appearing as those in GB.
- The notification bar is able to be pulled down even when the phone is locked.
- ADB connections unless acquired through recovery (use Terminal Emulator for now.)
- Some CyanogenMod settings are hard to find and some still have no functionality
- Camera is throwing up "Can not connect to camera." error.
- Some users are expirencing 16 bit color (again, to the "rays" bug)
- Wireless Internet (Wifi) - 3G is the only source to Internet at this time (at least, on my end.. Wifi doesn't work)
- Headphone Jack + Headphones + Line Out doesn't work. Built-in Speaker only works.
- Mic on headphones doesn't work either.
- Reboot Recovery on the power menu just reboots the phone as normal (am I doing something wrong?)
- Airplane Mode won't switch on the power menu, but changes in settings.
- ADB over network won't work... because Wifi doesn't work.
- Browser doesn't load web pages correctly. I tried MediaFire and I had to zoom in three times before I could see it.. then it took 3 minutes before it would focus.
- GPS takes a long time to lock. Tried to use GPS Nav by Google in the city in the car by a window and it took almost 5 minutes before it would lock... Maps in well, Maps loads relatively slow.
- Some CM apps are missing - Spare Parts and Theme Chooser..
- Syncing other than with Google doesn't work, either. Tried to sync with Facebook and it wouldn't go. I clicked "Add Account" and it stood there... not moving at all. :-/
- HW Camera button on the phone doesn't work. It just causes the Optimus to vibrate... The voice dialer button doesn't work either.
That's all I have for now..
Thanks kraven for putting out the new alpha build.
