Re: [WIP][ROM]COLD AS ICE-CM9 for Sprint LS670 ZVD basesband on
I am upgrading from gingerrom on my optimus S with zvj, I wiped data and cache, formatted boot, system, data, and cache, flashed the rom, flashed gapps, disabled signing, installed zvd to zvj patch, everything seems to work well except the data connection is much slower than usual, and inconsistent. I see that the rom flash installed Kernel 2.6.35.7-CAI-test23-HK+thekraven@ics18. I dont know if that has anything to do with it or I would be better off with a different kernel. Also what is the difference between the 2 gapps one with the DPI change on market, and the other with older voice command? I installed the first and the voice command doesn't seem to work. Any help or advice to get this smooth would be greatly appreciated.
side note: I baught an extra 32gb microsdhc class 10 for the phone. Can someone tell me the real benefits of D2SD, and if I can just set it up with what the rom already facilitates, and how?
