Tyler555
Active member
CWM But I'm fine with sd ext3 at 500mb but now the problem is I can't install non-market apps as the phone claims I have no internal space, when I have 70 mb free AND 400 mb of sd ext. I just got everything set up so, I don't really want to completely wipe and reinstall.
EDIT
Uninstalled S2E and rebooted, now home button doesn't work, settings are gone, and data is missing, it think the delvik cache and system cache got wiped.... sigh.... should have backed up earlier. Going to clean install, later, but what should I do different this time to ensure everything works and my sd-ext is working properly?
EDIT2
I'm almost certain some of the system partitions were deleted, Major UI elements are missing. Various other system apps are faulty/non-existent.
I'll just boot back to cm7.2 because this is un usable until I completely reinstall cm9 Cai... again what should I do different to ensure a proper install with a working 500 mb sd ext ext3 with journaling? Sorry for the trouble guys
EDIT3
HAHAHAHA.... on a whim I re-installed S2E and rebooted... Everythings back to normal, except the out of space error is still there for non market apps... some one please explain what has just happened haha
EDIT
EDIT2
EDIT3
