gingerc76
Umm noob question but where is the caller ID settings on this rom
Sent from my LG-LS670 using Xparent Purple Tapatalk 2
Every time I try CAI I always have problems with calling and the other person can't hear me, if I swap out the phone apk with one from Bobz ics will it fix that?
EDIT: It didn't work
Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
I recently flashed this and seems to be working great, thanks for the hard work.
I have been having issues with the mms (I'm on Virgin mobile with the optimus v and applied the patch), do you think reflashing or the Bobz mms.apk would help?
when are we going to see a new update?
Flash, boot, go to settings, select d2sd, reboot, then install your Apps as you normally would. Your apps will automatically go to your sd card (as does your data, incidentally.)
