SETTING UP LEWA ROM:
On the FIRST BOOT right after you flash the G'apps, you need to boot up and skip Google Sign IN.. we will come back to that later.
Follow the screens where it asks if it is okay for Google to gather information and blah blah blah
I forgot that rest of that part..
I somewhat ported this over from the O.V. Thread for LeWa ROM from Incredible Madness...
Anywho's - when your greeted with the LeWa ROM Home Screen Launcher, you need to fix your Data (3G connection)... When you go to settings, go to Mobile Networks,
find Access Point Names (APNs) and Tap on the APN starting with the letter "U" if there is one.. If so, find the one starting with the "U" and tap on it. Hit the menu key and choose DELETE. If prompted by a popup, delete it. I have found that this APN is found in most ROMs and I have also discovered that it is throwing the 3G connection up... Back on track... After you have deleted the one starting with the letter "U",
tap the little square next to "Sprint" and then under that it says "0".. Yeah.. tap that one..
HW Lights staying ON fix - Pull down the status bar and choose backlight.. Turn it on anything but auto.. That's okay.. we had this same prob in MIUI ZVD (RawrZilla)..
Phone Not Ringing (Silent RT Selected Message) - Go to Settings and Fling your finger to the left... once to get to "Personal" tab.. Select Sound and Vibration, and well.. go to Ringtone.. tap on both of them and set a ringtone... they will be set on "SILENT" as default.
LOCK SOUNDS - Go to Settings > Personal > Sound and Vibration > Screen Lock Sounds
Window Animations are not showing [FIX] - Go to Settings > Personal > Display > Window Animations.. Select "ALL"..
Mock Locations - Go to Settings > Applications > Development > Allow Mock Locations (TURN ON)
These are just a few fixes I found..
THANKS BUTTON IF I HELPED....
