My first ever tiny contribution FOR ZVD
Based of LeWa port by gannon (http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/158380-rom-alpha-2-3-7-lewa-os.html) from HTC Port by ajrty33 ([ROM][2.3.7] LeWa OS (02/24/2012) - xda-developers)
This is Kraven's CM7.2 + Gannons LeWa port.
Installation Instructions:
Format Cache
Format Boot/System/Data/Cache
Flash Debug-FormatSystem.Zip
Flash LeWa Madness (Turn off sig notification for now, will do once it qualifies for a beta)
Flash Gapps
Reboot.
Setup Instructions:
Once greeted on the setup screen, scrolldown notification bar. Long press on the Mobile Data icon takes you to the Data settings.
Scroll down to the access Point Names, select it and TICK the Sprint 0. You'll see the 3G icon on top.
Exit, scroll down notification again, long press WLAN. Takes to you wifi, set up you wifi.
Go back and long in to your google account. Download apps from Market.
Swipe up Dock to see your apps.
Customize Dock apps: Just swipe up your dock to show apps, drag what to want in/out of the Dock from App Drawer.
ROM Theme - Vfan/seven are my Favorites. There is a theme app that lets you download themes.
Weather Clock Widget - Go Weather
Lock Screen - Download MIlocker form Market. Create a folder called MIUI/theme on SD card (sdcard/MIUI/theme). Downloading MiLocker might create this, not quite sure. Place the attached .mtz file in the folder.
Go to MiLocker app and apply the theme.
Themes: rediem at XDA made a zip of 30-odd themes. Looks like it works only if you place them on the root of SD card.
Place on root of SD, go to theme app, select import. Let me know if it works. Thread - LEWA ROM Themes - xda-developers
Credits:
Every Dev at AndroidCentral - Sprint forums for keeping our beloved Optimus alive and kicking.
CM, Zefie, Drew, Thekraven for bringing us the CM7 & CM9
gannon for helping me out with and letting me porting this. Thanks Guru.
ajrty33 for the original port to Hero.
Le Frog Technology
Links:
ROM - Updated with email and gallery http://db.tt/KjN098ne . Latest by Almos.lalo - Click Here
gapps - http://db.tt/Tl919Ju7
MiLocker theme - http://db.tt/CIeuvgsh
More MiLocker Themes at XDA - [Milocker][devs help plz] mdpi, request and post it here ~ more than 45 themes - xda-developers
Format Cache
Flash Gapps
Reboot.
Setup Instructions:
Credits:
Le Frog Technology
Links:
