hello i need help with rooting baseband version mvj
Did you have the correct drivers installed?
Sent from my LS670 using Tapatalk 2
how did you revert from mvj to zvd
i did this to my phone and it rebooted back to 2.3.3 firmware with everything erased on my phone:-\
Also make sure you have the stock rec installed. It's the first thing mentioned on that thread. If you have xionia you'll have to run update twice (if i remember correct). that way stock recovery is installed (first run) then the radio will be flashed for service purposes (second run).i did this to my phone and it rebooted back to 2.3.3 firmware with everything erased on my phone:-\
ok tried it again and nothing, i\I downloaded the update.zip file to my pc then transferred it to my SD on my phone, When i went to update the update.zip my phone could not find it. Am i putting the update zip file somewhere wrong?
sorry if i dont make any sense
Are you putting it in a folder? If so, don't. Just put it on your sd card, but NOT in any of the folders. And make sure it's just named update.zip, bc windows likes to add another .zip on the end (essentially naming it update.zip.zip instead).
i think i got it i had to rename it just update stupid windows zip.zip thanks guys
