Its only working in Froyo based ROMs. For some reason, in GB based ROMs, sync is broken, and in ICS based ROMs, video, and sync is broken.
I wish I had the smarts to figure out why this is so, and attempt to fix it, but I'm simply not very educated in that specific area of programming. This issue is slowly starting to get more attention, someone over in the V forums is attempting to at least get video to play in Netflix on quattrimus. Not sure on their progress yet, but at least someone is trying.
I'm almost certain that its because ZVD is made for froyo, and since ZVJ(stock GB) doesn't play well with hardware acceleration, that when devs were building GB roms for FROYO firmware, that same issue with ZVJ stayed in GB roms for ZVD.. not sure what the official ICS firmware is(ZVR?? I think?? don't think I'm even close) But its even worse there..
(Technically, all GB roms are ZVJ ports to ZVD, unless built otherwise. So whatever is wrong with ZVJ, persists in GB roms for ZVD, which would explain why GB has sync issues with Netflix)
So unless some figures out why its broken in ZVJ, and makes a flash able fix for all GB roms, or another custom Netflix app, then it MIGHT be fixed.. these are just my theories that could be better explained, but I'm lazy at the moment.
sent from my un-dead sammich.
