[Patch's]ZVJ to ZVD & ZVD to ZVJ Flashable zips(Optimus S)
nitestalkr
889
261
Yea, I know... tapatalk and I have been going through a few misunderstandings recently.
Idk why it does that, it shows the second link in tapatalk xparent red... kinda
sent from my Zom-"Bean'(CM10 JellyBean).
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
@nitestalkr
I'm on zvd and I wanted to flash backside it looked cool....
Well flashed on vd radio and used zvj to zvd to get buttons but it failed. Suggestions?
thewraith420
1,987
223
63
@nitestalkr
Keys 102 and 139 need to be switched in qwerty.kl and thunderc.kl. In system/usr/keylayout/
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.1 on LS670ZVJ Baseband
pclov3r
17
Sadly it didn't work for me with CM 7.2 Had to flash ZVD with the stock recovery.
Just curious if there is a way to flash the radio image without the stock recovery? Would fix the base band problem altogether.
williek113
179
I flashed an optimus v rom on my S and everything worked but the wick, it wouldn't turn on and the thread for the rom itself said everything basically worked. I was on ZVJ and used the right patch
Sent from my LS670 using Android Central Forums
nitestalkr
889
261
You're supposed to use a custom recovery with this.
After rooted, install Drew's cannibal recovery(recommended), flash ROM, gapps, and corresponding patch.
If on ZVJ radio, use ZVD to ZVJ patch for all non ZVJ ROMs.
If on ZVD radio, use ZVJ to ZVD patch for all ZVJ and Optimus V ROMs.
weclee
3
love this. thank you guys for being awesome... gives new life to my optimus s, lol you guys are gonna turn me into a crack flasher. :p
nitestalkr
889
261
umm guys problem here, my phone says baseband unknown when i use the zvj to zvd zip
That's normal.
Some ROMs don't read the baseband versions, so don't panic.
If you know you're on, say ZVJ, and it says 'Unknown' then you're still on ZVJ.
Its a small bug in most ROMs, and isn't that important to fix, it causes 0 issues.
