3G wont work all the sudden?
therenegadenail
102
7
pretty much been running kravens cm9 forever with the zvd to zvj patch, and having no problems and then just the other day my 3G wont connect, can still make calls and what not, but nothing else, basically HAVE to connect to wifi to do anything, ive reflashed, no success, ive reinstalled previous backups where everything was fine, nope
any idea what is going on? and how to fix? havent dropped my phone or nothing
thewraith420
1,987
223
63
Tower work in your area? I had this issue also but it resolved itself in a day
therenegadenail
102
7
no yea tower is working, as my brother and mother have the same phones with the same roms and set ups and they get service no problem
im thinking something inside the phone must have broken :(
thekraven
1,407
1,148
Are you using any scripts or build.prop tweaks?
Try this in dialer. *#*#4636#*#*
Under phone, select cdma auto
Then turn the radio off and back on
therenegadenail
102
7
no build.prop tweaks other than the defaults in your cm9 19E build, and i tried what you just posted, no success, i think something broke in the phone at this point, its the only thing i can think of
Nikoczzzz
