upconvert
Re: [ROM][WIP] CM10.1 jb 4.2.2 The JBC alpha build
PAC rom is great! Awesome work!
I noticed that the bottom 1/4 inch of the touch screen wasn't registering taps or swipes. Turns out that the "pie" toolbar target area is set to the bottom of the screen by default. Find that setting under toolbars and set it to none if you want the bottom of your touch screen back.
So many features my optimus has never seen before!
